Author Topic: VRay Displacement Keep Continuity  (Read 2902 times)
RC2292
« on: December 05, 2022, 12:57:49 pm »
Before I lose my mind, can I check that Keep Continuity in the VRay Displacement Modifier should work with RC?
Re: VRay Displacement Keep Continuity
« Reply #1 on: December 05, 2022, 02:25:23 pm »
Would you mind specifying your scene set-up more in detail? If you’re applying the VRayDisplacementMod modifier over the RailClone object, I would suggest you "weld" vertices (by applying a Welder modifier or within an Edit Poly modifier) to see if that helps.
RC2292
« Reply #2 on: December 05, 2022, 07:32:08 pm »
Thanks for the reply Michal,
I'm applying the modifier to the segment used by a 2S Array.
« Reply #3 on: December 06, 2022, 11:31:08 am »
Thanks for your swift reply. I’m afraid, that using any “render-time modifiers” over Segments isn’t supported. Thanks for your comprehension.
RC2292
« Reply #4 on: December 10, 2022, 01:48:25 pm »
Thanks for letting me know Michal
