Author Topic: scalloped profiles  (Read 3269 times)
KD4391
scalloped profiles
« on: November 30, 2022, 05:12:20 am »
hi guys
i need to do this scalloped profile underneath the kitchen benchtops and these benchtops are also curved - is it possible to set up a railclone for this while retaining proportions around the curved areas?
a couple of examples below.
https://www.skheme.com/media/10055/colombian_2.jpg
https://marbleceramiccorp.com.au/stone-mosaic-capping-tiles/5315-carrara-concave-honed-marble-mosaic.html?gclid=Cj0KCQiA-JacBhC0ARIsAIxybyNaJTKJLs6yZZCejjs3tYsV982TPeODO-nofPc43OQWE67MTIsiAgwaAoJOEALw_wcB
many thanks
Simon
Re: scalloped profiles
« Reply #1 on: November 30, 2022, 09:37:34 am »
That should be fine, just wire the scallops to the Generator's Default input and make sure that you turn off Deform > Bend in the Segment Node's settings so that they don't deform to follow the curve.
Best,
KD4391
« Reply #2 on: November 30, 2022, 10:22:58 am »
Thanks Paul - however it doesnt really connect on the edges.
See attached.
« Reply #3 on: November 30, 2022, 06:26:50 pm »
Please try changing the Y Alignment for the Segment to Top. the issue at the moment is that it is aligning using the center of the geometry.
I hope that helps,
KD4391
« Reply #4 on: November 30, 2022, 11:05:22 pm »
Thanks Paul but its still not working for me?   see attached.  I also tried changing the pivot of the base object - couldnt get it to work - its overlapping.
Any chance you can do it and send the scene here so i can study what you did?
« Reply #5 on: December 01, 2022, 10:17:53 am »
Well, because of the way how the shape is done (by a Spline Chamfer modifier applied over a Rectangle), any “bending” would be deformed. After applying the Normalize Spline modifier and enabling the Deform > Bend option for the used Segment, the Adaptive mode seems to work just fine. Please find attached the modified scene. I hope that helps.
KD4391
« Reply #6 on: December 01, 2022, 11:01:51 pm »
ahhh right - that makes sense now thanks so so much
