Author Topic: Segments not being sliced across edges  (Read 6473 times)
HB2523
« on: October 09, 2017, 06:26:46 pm »
I've made a simple box and a closed spline with some Corners and Beziere corners. The Segment node with the box is set to both Bend and Slice but the slicing doesn't work propperly. It doesn't slice across the whole model but leaves edges intact that results in intersecting polygons. See the attached image. How can I fix this to get a better connections between the segments?
Re: Segments not being sliced across edges
« Reply #1 on: October 10, 2017, 12:01:47 pm »
You can adjust how Corners are handled under Generator's Rules > Corner > Bevel Mode / Bevel Corner etc. Also, the Alignment settings for used Segment will have influence over the final result. Hope that helps.
