Author Topic: UVW map Global  (Read 2621 times)
RealViz
    • RealViz
UVW map Global
« on: September 21, 2022, 09:42:12 am »
Is there a possibility to apply UVW mapping to the whole RC or 1S/2S generator? I mean, similar to adding a modifier over the RC?
THX
Re: UVW map Global
« Reply #1 on: September 21, 2022, 09:47:43 am »
Enabling box mapping for all the segments should give you that effect. For renderers that don't support this feature (basically everything except V-Ray) you'll need to disable the Instancing Engine for it to work. In which case you might find it's just as easy to add the modifier as in your screenshot.
Cheers!
RealViz
    • RealViz
Re: UVW map Global
« Reply #2 on: September 21, 2022, 10:10:11 am »
Unfortunately, just turning on BoxMapping doesn't work properly (off inst.). So I will solve it by adding UVW mapping as a modifier.
