Author Topic: Start & end controlled by sequence segment  (Read 4659 times)
arch3d
    • arch3d.pl
« on: February 03, 2019, 07:08:48 am »
Rokas,
Could you help me with this problem?
I have segments in sequence and start/end. Depends on segment in array start/end should change ( eg. if last element is yellow - should be sphere, if last element is green should be cone etc.) Same at start.
Dunno how to do it in simple situation ( don't mention if i hange seguence array )
« Last Edit: February 04, 2019, 10:05:04 am by arch3d »
Re: Start & end controlled by sequence segment
« Reply #1 on: February 04, 2019, 10:07:00 am »
Sorry, I do not understand the task.
I do not grasp the rules of the required setup.
arch3d
    • arch3d.pl
« Reply #2 on: February 04, 2019, 10:21:47 am »
i got start segment <- sequence of boxes -> end segment so:
first element of sequence of boxes - yellllow box -> start segment - sphere
first element of sequence of boxes - green box -> start segment - cone
last element of sequence of boxes - yellllow box -> end segment - sphere
last element of sequence of boxes - green box -> end segment - cone
i need connect sequence with selector i think
« Last Edit: February 04, 2019, 10:31:22 am by arch3d »
« Reply #3 on: February 04, 2019, 10:59:03 am »
and if element is else?
.... else
Yes, I think Sequence with exported index is the way to go. Please try to create Your setup and ask for help if still needed.
arch3d
    • arch3d.pl
« Reply #4 on: February 04, 2019, 11:14:52 am »
...and here is problem -  how to export index from sequence :D
you mean plug exteral numeric values and plug it to selector as well?
i tried in this way but if i changed values it didnt work
« Last Edit: February 04, 2019, 11:23:53 am by arch3d »
« Reply #5 on: February 04, 2019, 11:26:03 am »
I meant selector node, not sequence  :-[
arch3d
    • arch3d.pl
« Reply #6 on: February 04, 2019, 11:41:36 am »
yep i think can work:)
i didnt ectract all params before and it was a problem
Thank you very much
arch3d
    • arch3d.pl
« Reply #7 on: February 04, 2019, 12:53:22 pm »
hmm not so easy
if i got any points on spline it doesnt work...and using sequence counter i cant control first and last segment...
i need to get data from sequence...
and than somehow (probably expression way :/) implement it to selector
« Reply #8 on: February 04, 2019, 12:56:36 pm »
I don't understand what You are building and rules for that setup.
arch3d
    • arch3d.pl
« Reply #9 on: February 04, 2019, 01:04:35 pm »
2s array based on single spline :)
arch3d
    • arch3d.pl
« Reply #10 on: February 04, 2019, 01:09:04 pm »
and here is why i bother you about endings in sequence..
i dont want to use mat id
i have to use sequence for x corners ,and frames - it works ( even with mirrorr of array ) only problem is with start and end caps -  i can do it manually by exported selector... but i was looking for some auto solution :)
so my new idea is control sequence by expression conected to selector as well
« Last Edit: February 04, 2019, 01:33:33 pm by arch3d »
