Author Topic: System units issue  (Read 2544 times)
System units issue
« on: June 16, 2021, 03:42:32 pm »
Hi, can`t share a file but here is the question.
My RC Style scene is in centimeters and the client scene is in meters...
We have a scale issue.
Any workflow to solve this problem?
Re: System units issue
« Reply #1 on: June 16, 2021, 03:56:44 pm »
Solved...
Just set the global size to 10000%
:D
« Reply #2 on: June 17, 2021, 02:52:08 pm »
Hm.. still have a problem with
I tried with a different Style...
The Style is a mess  ;D ;D ;D but when merged to meters unit scene some of the segment remains unscaled...
« Last Edit: June 17, 2021, 06:30:45 pm by Dragan »
« Reply #3 on: June 17, 2021, 05:13:32 pm »
Again, never mind!!!
In this case, it was on my side!! :(
I had one numeric constant of value=2 set as an integer instead cm so after unit transition that value stays 2 instead 0.02 for cm>m in scene unit type.
The golden rule for RC: ALWAYS RESPECT UNIT TYPE!  >:( :-[
« Last Edit: June 17, 2021, 09:30:05 pm by Dragan »
« Reply #4 on: June 17, 2021, 05:55:19 pm »
Enhancement request: make scene units  as the default type for numeric node, for obvious reasons...  ;)
« Last Edit: June 17, 2021, 06:18:02 pm by Dragan »
