RailClone => RailClone Pro (*) => Topic started by: BJ2494 on November 16, 2020, 05:48:25 pm
I need help with this:
I wanted to make a brick wall with spaces between them and with an inclination as it goes up in height
Thanks and sorry for the translation(http://)
I had a macro for this but can`t find it now :o !
Give me a few minutes to build a new one.
Here is the Macro. My math for Vertical Adaptive+Vertical Gap is not correct at the moment but I don`t have time to solve this right now :(
Macro can work in 3 modes:
1. With the Wall Heigth parameter (Y Spline not assign).
2. With X/Y Spline (Y Spline is assigned and it controls height)
3. Clipping Spline > When Clipping Spline is assigned and `Use Clipping.Ext.Size`check box is ON. (If the Check box is OFF Clipping Spline will act as ordinary clipping for the first two modes)
note; You can get some interesting results by exposing parameters and adding some Random/Arithmetic Nodes.
eg. I exposed the Z offset parameter and connect the Random Node set with values -3 to 3 and generate on SEGMENT. This will result in randomness for each brick...
Please let me know if you need more info about the parameters.
Best Regards
Please MAX 2019
Thank you
I`m using MAx2018.It should work on Max2109.
sorry, Max 2017
Sure.
thank you very much, great job :)
