Author Topic: Snap to RailClone objects from library  (Read 3396 times)
HU0164
« on: November 28, 2023, 05:19:46 pm »
Hi, I just bought the FP+RC Bundle (thanks to Black Friday), I'm on 3DS Max 2024.
I have a problem, I can't snap to (vertex, edges, faces) on the RC objects in the library.
Is this because they're embedded?
Is there a method?
Thanks for your help.
Re: Snap to RailClone objects from library
« Reply #1 on: November 29, 2023, 08:58:32 am »
That will most probably be linked to the used Display > Viewport mode (Quick Mesh / Points-Cloud). Instead, when using the Mesh mode, you should be able to use the snapping feature on it without any trouble. I hope that helps.
HU0164
« Reply #2 on: November 29, 2023, 09:11:13 am »
thanks, you've just solved my problem.
Bravo !
Have a nice day.
