RailClone => RailClone Pro (*) => Topic started by: AY2121 on September 06, 2022, 12:22:41 pm
I have 3 components that I have made into a wall module in rail clone. I am trying to snap it to a spline. On the original clipping area spline it shows correctly but once I replace that spline for the chosen one it does not show at all. How may I fix this? any help would be appreciated. Many thanks in advance. (I have tried to attach photos but I am new, sorry ;D )
Kind regards,
David
Hello David,
Welcome to RailClone :)
I'd be happy to help. You can upload images and ideally a sample file using the attachments options at the bottom of the Post Reply window.
(https://i.imgur.com/EJHddTL.png)
Best,
Hahaha it was that simple! My bad. Thank you for the fast reply.
I have attached the scene file and some images. I hope this helps.
I am sure it is a simple fix. I am just unsure as to what I need to do. ;D
Thank you again for the help.
Kind regards,
David
*Update*
I have managed to get the facade to snap to the other rectangle. However, it is not correct. I am thinking it might have something to do with the axis.
I will keep exploring to see what happens in hope to achieve the desired finish.
8)
Hello David,
Please see the attached file. It looks to me like enabling Auto-Align > X->XY solves this for you. THis option will automatically align the array to a closed spline.
I hope that helps,
This method worked perfectly.
Thank you so much! :)
