RailClone => RailClone Pro (*) => Topic started by: ST3200 on October 02, 2024, 01:28:23 pm
Title: Some problems
Post by: ST3200 on October 02, 2024, 01:28:23 pm
I was trying to follow and tutorial from 6 years ago  ( https://youtu.be/vqS4ode_8gM?t=582 )
To have the grout of the floor, I need to check "overide fixed size",but it is not said in the video. Something have changed or there is a problem ?
I don't use usually box mapping in Rail clone, but I tried but I can't succeed, nothing happen ? Any idea ?
Title: Re: Some problems
Post by: Michal KarmazĂ­n on October 02, 2024, 03:26:32 pm
As you mentioned, the 'Mastering Procedural Modelling in 3ds Max (https://www.itoosoft.com/tutorials/mastering-procedural-modelling-in-3ds-max)' tutorial was recorded a few years ago, before the 'Override Fixed Size' checkbox was introduced. Which renderer are you using? You may need to disable the instancing engine (https://docs.itoosoft.com/railclone/display-settings#to-enabledisable-the-instancing-engine) to enable the Apply Box Mapping feature. I recommend checking the 'Feature Compatibility (https://docs.itoosoft.com/railclone/requirements#feature-compatibility)' table for further details.
Post by: ST3200 on October 02, 2024, 04:45:23 pm
Thanks !  :)
