Author Topic: Spiral Staircase  (Read 6352 times)
EI3056
Spiral Staircase
« on: February 25, 2020, 10:07:52 am »
Hey,
I tried to make a half-spiral staircase in RailClone, but always end up with some issues.
I´ve adjusted the RailClone object from this file: https://forum.itoosoft.com/railclone-pro-(*)/spiral-staircase/msg6915/#msg6915
The "inner" side of the stairs looks good and every step has the same depth.
The "outer" side looks weird. I´ve attached a screenshot and the RC File.
Any idea how I can fix this issue?
Thanks!
Re: Spiral Staircase
« Reply #1 on: February 25, 2020, 02:44:00 pm »
To fix Helix shapes for RailClone, You should do the following:
Set Spline Segment type to Curve
Set Vertex Type to Smooth
Hope this helps.
EI3056
« Reply #2 on: February 26, 2020, 10:48:42 am »
Hey Rokas
Thanks for the reply, that´s an easy fix.
