Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Spline from Autocad Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Spline from Autocad Problem (Read 5672 times)
HU0164
Jr. Member
on:
November 21, 2025, 09:25:32 am »
I receive 2D AutoCAD DWG files from surveyors.
I am almost never able to apply a RailClone object to splines from DWG files.
What do I need to do to make it work?
Logged
ITOOSOFT
Hero Member
Re: Spline from Autocad Problem
Reply #1 on:
November 21, 2025, 09:32:42 am »
I'm sorry to hear you're having trouble with it. Could you please describe the issue in a bit more detail? Are the RailClone styles you're using based on the spline’s
Material ID
s? If so, let me mention that, as noted
here on our forum
"... upon my experience, in case of importing splines from a
.dwg
file, its Color is used for generating the 3ds max
Material ID
. If you want to avoid the
Edit Spline
modifier step - assigning the
Red
color to such spline (layer) should result in
ID 1
Yellow
as
ID2
(as the Red color should be indexed 1 (Yellow 2) in AutoCAD)."
Logged
HU0164
Jr. Member
Reply #2 on:
November 21, 2025, 09:56:46 am »
Yes, that's right.
I can't integrate this parameter into my head. It must be old age.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
