RailClone => RailClone Pro (*) => Topic started by: OT3376 on April 02, 2025, 02:58:04 pm
Title: staggered flat tile roof with end caps
Post by: OT3376 on April 02, 2025, 02:58:04 pm
Hi all,
I'm trying to make a staggered flat tile roof with left and right end caps attached.
I can easily make a non staggered tile roof with left and right end caps (the end caps are attached to the tile models L and R) see image attached
But I'm not sure how to make a staggered tiled roof with end caps. The staggered roof uses full tile and a one and a half tile to make the stagger. But I'm not sure how to make the verge edges only use one and one and a half tiles with end caps attached.
I've attached shots and a maxfile. Hope this is clear. Bit tricky to explain
(http://[img])[/img]
Title: Re: staggered flat tile roof with end caps
Post by: Michal Karmazín on April 02, 2025, 03:16:01 pm
In a very similar way, you can alternate between FLAT_TILE_VERGE_L and FLAT_TILE_1.5_VERGE_L by using the Sequence operator connected to the Start Input, along with the Mirror operator for the End Input. Please find attached a revised version of your scene (250402_Roof_tiles_ITOOSOFT.max). I hope this helps.
Post by: OT3376 on April 03, 2025, 10:56:57 am
thanks for that. It's almost perfect. Only one thing, where the right hand verge tiles are mirrored, the interlock is incorrect. Image attached. I could adjust the geometry of the model so that there is no interlock and then they will just butt up together but it would be good if this could be fixed within Railclone so it has the correct interlock on the mirrored side. Many thanks. Scene attached
Post by: Michal Karmazín on April 03, 2025, 11:53:25 am
I see, I hadn't noticed that before. In this case, instead of using the Mirror operator, you can directly wire the corresponding segments (FLAT_TILE_VERGE_R & FLAT_TILE_1.5_VERGE_R) and adjust the padding as needed. Please find attached the modified scene (250403_Roof_tiles_ITOOSOFT_REV.max). I hope that helps.
Post by: OT3376 on April 03, 2025, 03:26:41 pm
Great! thanks very much for being so prompt.
