Author Topic: Street lights + barriers (combine)  (Read 7442 times)
Re: Street lights + barriers (combine)
« Reply #15 on: November 06, 2020, 09:40:54 am »
This is probably due to combining adaptive vs vertical and stepped deformation in Sequence.
Try to make a NULL segment with X Fixed size that matches the pole to make empty space and use a separate generator do the oposite NULL for barriers.
« Last Edit: November 06, 2020, 09:44:27 am by Dragan »
« Reply #16 on: November 06, 2020, 09:44:16 am »
seems like a bug. Logged to our system. Thanks for reporting.
zeffs
« Reply #17 on: November 06, 2020, 09:52:40 am »
Thx )
« Reply #18 on: November 06, 2020, 10:21:47 am »
I created a workaround RC objects.
Please check if that works for you.
« Last Edit: November 06, 2020, 10:43:26 am by Dragan »
zeffs
« Reply #19 on: November 06, 2020, 11:22:48 am »
Cool! That works!
the only thing - I don't understand how to get those additional fields for segment and transform nodes ))
« Reply #20 on: November 06, 2020, 11:48:31 am »
Cool! That works!
rightclick on the node and export internal parameter or size attribute.
« Reply #21 on: November 06, 2020, 11:52:52 am »
Oh..welll...
you should go with https://docs.itoosoft.com/railclone/getting-started-with-railclone
and check all from:
https://www.itoosoft.com/tutorials?page=1
answer to your question: right mouse click on the node and you will see Export Parameters & Attributes
Parameters are like Inputs and Attributes are like Output Values...
But, please go to trough Documentation and Tutorials. RailClone is a very powerful tool if you know what you are doing  ;D
« Reply #22 on: November 06, 2020, 11:56:34 am »
 ;D ;D ;D ;D
@Rokas STOP ANSWERING WHILE I`M  TYPING MINE REPLY!!!
 ;D ;D ;D ;D
It is like I`m Copy/Paste from you and acting like an idiot!
 ;D ;D ;D ;D
edit:
@zeffs
You can see the Itoo Support is the best support you ever encounter.
« Last Edit: November 06, 2020, 12:04:06 pm by Dragan »
« Reply #23 on: November 06, 2020, 12:08:04 pm »
Agree with dragan. We have put a lot of work into documentation. We hope it is clear to understand and useful.
zeffs
« Reply #24 on: November 06, 2020, 12:20:30 pm »
Thanks guys! this one is solved!!!  ;) :D
