Author Topic: StyleEditor suggestions  (Read 24792 times)
Re: StyleEditor suggestions
« Reply #15 on: January 11, 2014, 07:20:50 pm »
I think there is not an easy way to change this behaviour (it's hard coded in the API), but i'll look it.
harumscarum
    • harumscarum's portfolio
« Reply #16 on: January 18, 2014, 11:25:47 am »
there are same parameters under different names. whether it was appropriate to name them the same? thanks)
« Reply #17 on: January 18, 2014, 11:57:41 am »
Sure. I just renamed them.
harumscarum
« Reply #18 on: January 28, 2014, 04:37:24 pm »
is Transform supportind Adaptive Mode (Rules - Deform)? Padding only working if set in segment, but not in Transfrom node
thanks
« Reply #19 on: January 29, 2014, 09:27:24 am »
You are right. Adaptive mode is not working well with the Transform operator. We'll check it.
harumscarum
« Reply #20 on: January 29, 2014, 07:39:01 pm »
two suggestions
1 - "OR" condition so it will be possible to add multiple spline IDs
2 - "seed" for Randomize node in order to select from different random combinations
« Last Edit: January 29, 2014, 08:31:54 pm by harumscarum »
« Reply #21 on: January 30, 2014, 04:37:50 pm »
1.- I'm afraid would be problematic to define a multiple list here. I'll think if there is some alternative.
2.- Randomize node uses the seed defined in the "General" rollout, and each node generates its own random values. Do you need a local seed for some specific reason ?
harumscarum
« Reply #22 on: January 30, 2014, 04:54:59 pm »
1 - if possible to number of comma separated IDs like "1, 3, 5" it will be enough
2 - thanks - it works for me. could be useful if there are several arrays in railclone to have seed per array
« Reply #23 on: January 30, 2014, 05:05:02 pm »
1.- That would work, but to change the type of a parameter (from integer to string) may break the compatibility with existing styles (specially if the parameter was "exported").
2.- Yes, a local seed by Generator has sense. I add it to the wishlist.
harumscarum
« Reply #24 on: January 30, 2014, 05:14:53 pm »
1 - i understand... in order to keep compatibility with existing styles, maybe exported Limit Mat.ID could be used for this purpose
« Last Edit: January 30, 2014, 05:18:40 pm by harumscarum »
harumscarum
« Reply #25 on: February 01, 2014, 01:34:19 pm »
there is Flip feature in RC settings, but for some cases need to Mirror copy for specific segment.
could be this option added to the Mirror node?
thanks)
« Reply #26 on: February 02, 2014, 10:16:46 am »
I'll take a look to it. Due to the instancing engine, there are certain restrictions about what operations can be done from an operator.
harumscarum
« Reply #27 on: September 10, 2014, 05:02:49 pm »
just two suggestion.
1. copy nodes with SHIFT+drag
2. hotkey for automatically align selected nodes
3. move children nodes by ALT+drag (instead ALT+LMB+drag)
« Last Edit: September 11, 2014, 09:29:58 am by harumscarum »
OB
« Reply #28 on: September 11, 2014, 09:30:37 am »
I am not sure if these were suggested , but
1. It would be cool if wire will be connected automatically to a slot of a node by dragging it over node itself , not just on the small green circle , well at least on some obvious nodes - for example when you are connecting segment and randomize node , you drag it over node and it wires it.
2. Recently i found a bit boring to add about 20 segments of geometry :) Is there possibility to use ctrl+c in viewport and after that ctrl+v in StyleEditor to paste geometry as segments ?
Thanks for your great work !
harumscarum
« Reply #29 on: September 11, 2014, 09:47:49 am »
http://forum.itoosoft.com/index.php?topic=2400.0 - do you mean that? just posted similar suggestion
2. Recently i found a bit boring to add about 20 segments of geometry :) Is there possibility to use ctrl+c in viewport and after that ctrl+v in StyleEditor to paste geometry as segments?
great idea! escpecially if it is possible to do with macroscript to put hotkeys manually
3. i'm also missing hotkey to open StyleEditor of selected RC object
« Last Edit: September 11, 2014, 09:55:13 am by harumscarum »
