RailClone => RailClone Pro (*) => Topic started by: FJ7201 on January 17, 2017, 12:03:02 pm
Hi , i want to do floor tiles and and wall socet tiles , same size to fits joints on both . First i try to do it by one 2s array add segments on sides and corners and it works perfectly in case simple shapes, but in more complicated fg L shape don't. So i try to do it by two arrays floor by 2s and wall socet by 1s it works better but i dont have any idea ho to fits joints, i attached screen to show what i mean , any sugestion most welcome .
Because of the way, how the array is constructed when using the Extend X/Y Size to Area feature, it's tricky to get Segments on "clipped borders" aligned with such array. An option might be to use X & Y Splines (or X & Y Size as on attached sample scene) instead to build these using additional Generators. Hope that helps a bit.
Best regadrs,
Hi, I'm having the same problem.
Is there a more recent procedure for obtaining this result?
