Author Topic: Update master style - copy material  (Read 7917 times)
RealViz
    • RealViz
« on: January 06, 2025, 12:40:12 pm »
Hi, if the Update button is pressed on an RC that has a MasterStyle defined and at the same time does not have CopyMaterial checked, the material will still be overwritten :-(
Re: Update master style - copy material
« Reply #1 on: January 06, 2025, 01:05:40 pm »
To avoid overwriting the material on linked objects, make sure the Copy Material option is not selected within the Master Style object. This should resolve the issue.
RealViz
    • RealViz
« Reply #2 on: January 06, 2025, 02:09:26 pm »
Thanks, that works. Anyway, it doesn't quite make sense :-)
