RailClone => RailClone Pro (*) => Topic started by: Jim Kessler on July 25, 2017, 07:01:45 am
I accidentally selected the wrong option about setting the paths after install, now I get this. How can I fix it? I've tried to uninstall and reinstall of RailClone.
Hi Jim,
That's really strange. Which RailClone Pro version are you using?
I would suggest you to delete all keys under
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\RailClone Pro
HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\RailClone Pro
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Itoo Software\RailClone Pro
and reinstall the plug-in. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Best regadrs,
I'm using RailClone 3.0.7. I'll give the registry edit a try.
Uninstall -> regedit -> Reinstall....did the trick. Thanks.
