RailClone => RailClone Pro (*) => Topic started by: Morne on April 29, 2022, 11:01:39 am
Title: Post and Rail 2 preset - Weird Segment Limit issue
Post by: Morne on April 29, 2022, 11:01:39 am
Can somebody figure out whats wrong with this RC object please...
Its from one of the default fence styles that comes with RC, but I modified it by replacing the round posts with square ones. Its a short fence (well short relative to our regular projects), but it keeps complaining about segment limits. Switching to point cloud or adaptive makes no difference.
I increased the limits dramatically already, however I dont see why I need to in the 1st place its a relatively short fence!
Attached zip is Max 2022 format
Title: Re: Weird Segment Limit issue with Timber Fence
Post by: Dragan on April 29, 2022, 01:43:29 pm
Can`t open the file due Max version but try set limits to 0
Post by: Morne on April 29, 2022, 02:10:56 pm
If I set only segments to 0, then max hangs
If I set faces to 0, then I still get the warning
Attached is a Max 2019 version of the file...
Post by: Paul Roberts on April 29, 2022, 02:53:31 pm
Hi Morne,
Do you remember which preset this was? There are a couple of post and rail presets but as far as I can tell they already have square posts. They also import to this scene as a new RC object much larger than yours so I wonder if the RC object could have been scaled which could cause some issues.
Post by: Dragan on April 29, 2022, 03:07:41 pm
It`s your bottom input for the Panel generator that is causing the problem.
Post by: Morne on April 29, 2022, 04:13:31 pm
To be honest I cant remember from which of the presets it came from.
I just know its an object we used from few years ago that's been recycled and everytime we need a similar fence with slight adjustments, we just adjust this one. So it could have gone corrupt somewhere along the line.
But now, how do I fix it? Easier to remake from scratch?
Post by: Dragan on April 29, 2022, 04:49:01 pm
You are using same segment for top and bottom. That segment has Y translate. Just pay attention to those. If the height of the fence is larger then this Y translate it will work fine. Don't have max now to fix this for you. Sorry. I'm on the phone at the moment.
Post by: Morne on May 04, 2022, 08:52:03 am
Still no joy fixing this...
Post by: Morne on May 04, 2022, 10:40:42 am
Hi Morne,
Hi Paul
Its the "Post and Rail 2" preset
