Author Topic: Sequence of Generators & Marker  (Read 6079 times)
arch3d
    • arch3d.pl
« on: December 13, 2020, 05:35:33 am »
sorry for stalking you again :(
here is some problem:
i got two generators as sequence of default segments, i would like to separate them by marker and assign it to part of spline ( e.g. ID=2 )
is it even possible?
problem cause limits, i know RC consider whole spline
if i turn them off works fine even if structure isn't perfect
« Last Edit: December 13, 2020, 05:52:50 am by arch3d »
Re: Sequence of Generators & Marker
« Reply #1 on: December 13, 2020, 08:56:01 am »
You can handle the rest  ;)
arch3d
    • arch3d.pl
« Reply #2 on: December 13, 2020, 11:15:27 am »
Thank you very much,
But how to limit sequence to deired matID?
« Reply #3 on: December 13, 2020, 11:42:05 am »
I`m not sure I understand.
Do you need an additional limit for the spline IDs?
arch3d
    • arch3d.pl
« Reply #4 on: December 13, 2020, 12:44:18 pm »
much more closer, i hope screen will explain what i want
« Last Edit: December 13, 2020, 12:50:28 pm by arch3d »
« Reply #5 on: December 13, 2020, 01:36:52 pm »
Just enable mat id limit in main generator.
« Reply #6 on: December 13, 2020, 02:07:43 pm »
This will change the start position of the marker.
Strange, I tried with selector Selector, Compose+null for termination, Conditional, nothing works as should.
arch3d
    • arch3d.pl
« Reply #7 on: December 13, 2020, 02:12:05 pm »
i know it could be RC limitation :(
« Reply #8 on: December 13, 2020, 02:16:51 pm »
Ah I see. Yes it is.
« Reply #9 on: December 13, 2020, 02:44:44 pm »
You could do a workaround with conditionals.
arch3d
    • arch3d.pl
« Reply #10 on: December 13, 2020, 02:58:09 pm »
nice!
arch3d
    • arch3d.pl
« Reply #11 on: December 13, 2020, 03:06:18 pm »
so if i would extract position of marker on spline i could use it as conditional's spline position am I right?
« Reply #12 on: December 13, 2020, 03:53:43 pm »
Yes.
I don`t know why the Conditional Length of the Full spline is not working. Possible bug again.
When the marker is connected it will automatically make a Section on the spline so you probably can calculate the marker position in Percentage.
I guess something like XSectionLength/XSplineLength*100. (connect this to Conditional node). Although I`m not sure how this will affect Sequence change. It is possible that some of the Sequence segments `crossover` the Marker Cone Segment. Then you just make the threshold by multiply with a value around 100. +/-80/90...
I can test it when I get my hands back on the computer.
