RailClone => RailClone Pro (*) => Topic started by: swavec on September 22, 2018, 09:50:29 am
I have this problem with clipping windows on windows from other side. Cant make sens of it as it dont happen on all windows from other side of facade.
Please try different Hierarchy Checking modes:
(https://i.imgur.com/FkI8UrG.png)
Using By Mat.ID should be the best one in Your case. You just need to assign correct ID to Your window splines.
If that does not help please attach Your file and we will check it.
That option is grayed out.
It is greyed out because You have set Limits by Mtl ID:
(https://i.imgur.com/9utm3J2.png)
Please disable that and Hierarchy -> None seems to do the trick:
(https://i.imgur.com/kTATcpC.png)
