Author Topic: Windows open en close  (Read 2817 times)
Remco
« on: November 01, 2020, 12:09:21 pm »
i have managed to create the window's i want. but i can't figure out how to make the windows to go open and close the right way?
i want to randomley open some windows and swith to tilt. i also have the script from Dragan but it is to difficult for me for now :)
some pointers in the right direction wil be appreciated
Re: Windows open en close
« Reply #1 on: November 01, 2020, 01:51:48 pm »
Hi Remco,
Please, can you downgrade the file to Max2018?
Remco
« Reply #2 on: November 01, 2020, 03:07:08 pm »
i thought it was saved for max 2018
« Reply #3 on: November 01, 2020, 03:39:46 pm »
Nope, still can't open  ???
Remco
« Reply #4 on: November 01, 2020, 03:44:43 pm »
New try
« Reply #5 on: November 01, 2020, 09:16:02 pm »
Sorry for the delay, Sunday  8)
Please check the Macro for generating vertical and horizontal bars. (green note)
With this, you can easily make a Style for various combinations.
Depending on the selection of which bar will be enabled you can add Frames and set size/padding/offsets using nods on the blue note.
Let me know if you need more info.
« Reply #6 on: November 01, 2020, 09:32:26 pm »
If I found some time I`ll make a macro that can make the whole window based on Bar selection.
A lot of people downloaded Macro for Windows Frame but seems it is still somehow complicated for a newbie.
Remco
« Reply #7 on: November 01, 2020, 09:42:40 pm »
I did not expect many people to respond on Sunday :)
thanks for the new macro, it does exactly what I want, but it almost breaks my computer  ::)
all day i am trying to simplify youre other script (les functions), and this one look more complicated   :) :)
i'm just starting creating my own stuff for railclone for a couple of days and already learned alot!
« Reply #8 on: November 01, 2020, 10:36:27 pm »
Yes
Macro is massive  ;D It was created during beta testing for RC4 so it is filled with everything. I could make it simpler and faster if some parameters are reduced.
But let make it more complicated  ;D ;D ;D
Check this Style. Depend on the bar selection, you turn on/off the Frame Macros you need. You can make different RC objects for different windows and set Limit by Material ID on the Master Generator eg. mat id 1 for Single, mat id 2 for double, mat id 3 for Split up/single down etc.  Then you can use all those RC Objects on unique Spline with different IDs.
« Last Edit: November 01, 2020, 10:48:43 pm by Dragan »
