Author Topic: Y Spline Array 2S  (Read 3421 times)
Sergey_Dobrij
Y Spline Array 2S
« on: October 19, 2021, 06:29:00 pm »
Hello! In what projection do you want to create the Y-axis spline? The documentation says "It is not necessary to align the Y spline in 3D space. Just create it on any XY plane, RailClone gets the origin and extent of the spline automatically, using the local X/Y vertex positions. Z is ignored.".
I am creating a spline in front view and I have this.
If I convert Y Spline to X / Y everything works. But in the lesson, everything is defaulted
Re: Y Spline Array 2S
« Reply #1 on: October 19, 2021, 07:40:24 pm »
How is your RC object (Icon) oriented? Usually, it should be placed on X/Y plane.
« Reply #2 on: October 19, 2021, 07:51:56 pm »
Also, check those two parameters: Y Spline, X Rotation
Sergey_Dobrij
« Reply #3 on: October 19, 2021, 08:00:21 pm »
Hi, Dragan!
In the lesson file, everything is by default and everything works. But as soon as I draw a new split in front view and plug it in, everything breaks (
Sergey_Dobrij
« Reply #4 on: October 19, 2021, 08:06:25 pm »
Therefore, everything is already confused in my head. Perhaps it was created in a different version and there were spline manipulations at the vertex level ?!
« Reply #5 on: October 19, 2021, 08:55:11 pm »
Try to apply Reset XForm on the Y spline.
« Last Edit: October 19, 2021, 08:59:45 pm by Dragan »
Sergey_Dobrij
« Reply #6 on: October 19, 2021, 08:56:23 pm »
If I rotate along the X axis then the following happens
Sergey_Dobrij
« Reply #7 on: October 19, 2021, 08:57:44 pm »
Can you share the scene file?
Thank you!
« Reply #8 on: October 19, 2021, 09:15:09 pm »
Pivot on your Spline has a different orientation.
pic of what I have changed in Generator:
« Last Edit: October 19, 2021, 09:19:45 pm by Dragan »
Sergey_Dobrij
« Reply #9 on: October 19, 2021, 09:39:22 pm »
Thanks! I also changed in the generator Y spline, to X / Y. And I did pivot manipulations. The question is, why does the lesson file work as it is?
the documentation also says - Defines what coordinates are used for the Y Spline: Y/Z or X/Y.
Note that X/Y was the mode for RailClone 2 objects. RailClone 3 objects uses Y/Z mode by default, which is more logical.
Sergey_Dobrij
« Reply #10 on: October 19, 2021, 09:40:37 pm »
Sorry to bother you). But I am a person who, until I understand thoroughly, will not give himself rest!)
Sergey_Dobrij
« Reply #11 on: October 19, 2021, 10:02:23 pm »
I do not just ask questions, I spend many hours reading and practical work in person to contact the forum. And my desire is to learn to get it right
« Last Edit: October 19, 2021, 10:05:57 pm by Sergey_Dobrij »
« Reply #12 on: October 19, 2021, 10:59:21 pm »
Don't worry, you are on the right track.
I also often come to a solution with trial and error. With time you will at least know where to target those trials.  ;D
Tutorials are great but also keep track of the forum and all the topics because Itoo guys are giving great support in answering all specific questions.
Sergey_Dobrij
« Reply #13 on: October 20, 2021, 07:11:38 am »
Thank you!
