Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
spline Mtl ID problem
« previous
next »
Print
Pages: [
1
Author
Topic: spline Mtl ID problem (Read 3063 times)
IS4550
Newbie
on:
July 03, 2019, 01:59:12 pm »
I want to make a default stone curb with IDs 1 and 2*.
And when I change my spline Mtl ID to 2, curbe doesn't follow the spline? Did anyone had similar problems?
Thank you
Last Edit: July 03, 2019, 03:13:43 pm by IS4550
Logged
Hero Member
Re: spline Mtl ID problem
Reply #1 on:
July 03, 2019, 03:08:18 pm »
Hi. Welcome to the forum.
We can take a look in Your situation only if You attached or
shared
Your files.
Logged
IS4550
Newbie
Reply #2 on:
July 03, 2019, 03:21:08 pm »
Thank you, I have placed the max file in the attachment
Logged
Hero Member
Reply #3 on:
July 04, 2019, 10:16:18 am »
That's a limitation of using material IDs.
RailClone splits the spline so curves that bridge IDs are no longer a continuous smooth sweep.
You can check workarounds for this issue in
this thread
Logged
IS4550
Newbie
Reply #4 on:
July 04, 2019, 11:49:33 am »
Thank you very much for the response, it is much appreciated.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
