Author Topic: "xxx.max" is not a valid object RailClo  (Read 4501 times)
avalon
« on: December 21, 2011, 04:54:10 PM »
I follow the tutorial :
I create an object ,save in a files .create lib and folder :but when i want to create a railclone object i have an error :
"Error loading style, template "xxx" from "xxx.max" is not a valid object RailClone"
Are they limitation ?
Sorry for bad english :)
Re: "xxx.max" is not a valid object RailClo
« Reply #1 on: December 21, 2011, 08:07:57 PM »
What type of object do you save in the Max file, a mesh or a RailClone ?
It should be a RailClone object, because the library get the style from it.
avalon
« Reply #2 on: December 21, 2011, 09:04:17 PM »
hi Itoo,
Many thank for your quick response :
It's a mesh,i do not know how to transform a mesh into a railclone objet ...
I've another question :
Does railclone support maxwell render's proxies ? it seem's not... :(
thx ,
avalon
« Reply #3 on: December 21, 2011, 09:30:24 PM »
You must create the RC object manually, assigning the segments, parameters, etc. The idea is that you use the library to store your own RC objects, but they must be created before.
No, i'm sorry. Anyways, we have some ideas about it for next releases...
avalon
« Reply #4 on: December 22, 2011, 08:28:44 AM »
Ok ,thank itoo :)
I understand how it works ,now.
maxwell proxie's :
"No, i'm sorry. Anyways, we have some ideas about it for next releases..."
It would be very great and powerfull :)
« Reply #5 on: December 28, 2011, 11:01:55 PM »
We just updated the plugin to v.1.3.0. With this release it is possible to use Maxwell proxies or other renderers in the following way:
- Assign the proxy to the Segments panel. Turn off  the "Bend" and "Slice" parameters, to be sure the segment is not deformed.
- Create your RailClone object, adding other segments and adjusting the parameters.
- When ready, use RailClone Tools to convert the geometry to standalone objects. The tool will create meshes and instances of the segments (including proxies) where needed.
