Author Topic: Wishlist and Question Railclone Pro  (Read 3416 times)
ML2660
« on: September 06, 2012, 11:05:22 AM »
Hi There,
RC is fantastic but I would like to make some suggestions to make life even more easier for me and other users.
Select the RC object from the quad menu, when selecting the spline.
Drag n drop library thumbnails for custom objects.Or even better, drop RC objects and thumbnails in to the library.And/Or like FP the import objects function.
Ability to rearange library objects and move/copy them to and from different custom libraries.
An Icon in the 3dsmax toolbar for RC creation/ Item in Quad menu for RC creation
Also a question:
When i want to use vray displacement in the vray material, I sometimes have to disable the vray/MR shader in the display settings.
Is this normal?
Is it also possible to apply a vray displacement mod to the rc object, and save the mod also with the rc library object?
Maybe some things mentioned above are already possible, but overlooked by me.Sorry in advance.
I'm using Railclone Pro 1.42 . and max 2011.
Best Regards,
Guido
Re: Wishlist and Question Railclone Pro
« Reply #1 on: September 06, 2012, 08:25:16 PM »
Hi, thanks again for your suggestions ! (for RailClone in this case)
Now it is possible to select the spline from RC using the quad menu, but i think the inverse process is not possible.
The Drag n Drop support is very limited in Max, but we have plans to add a RC->Library export button.
Ok. We can implement it for Forest and RailClone, since both plugins share the library functions.
Ok
Is this normal?
Yes. The VRay shader is used to create instances of the segments which are identical in a RailClone object. So it allows to render huge structures using minimal resources (lets say that RC creates automatically "proxies" where possible).
But since displacement tesellation is view-dependent and object-dependent, V-Ray cannot use it on instances, because each object should be different. This limitation exists also when applying displacement to proxies.
No. The RC objects in the library cannot include modifiers. Anyway, if you apply a modifier to RC it works as a standard mesh (the instancing support and the VRay/Mental Ray shader are disabled).
ML2660
« Reply #2 on: September 07, 2012, 09:58:21 AM »
Hi Carlos,
Thanks for the replies and great support! (also for the replies in the FP forum)
It's a shame wishes don't always come true  :)
Looking forward to see some of the changes being implemented.
Guido
