Author Topic: Railclone object disappears  (Read 6081 times)
Pierre
    • Studiosezz
« on: January 27, 2011, 02:31:35 PM »
I use Railclone for a building facade but in the perspective viewport  it disappears regularly (in the viewport only) , i have to hide / show the object to make it appear again.
have you ever had this problem?
Thank you
Pierre
Studiosezz PARIS
www.studiosezz.com
yuv
  • iToo Software - CEO
    • Itoo Software
Re: Railclone object disappears
« Reply #1 on: January 27, 2011, 03:17:32 PM »
No, we had not seen this problem before. What Max version and display driver do yo use ?
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
Pierre
    • Studiosezz
« Reply #2 on: January 27, 2011, 03:52:54 PM »
I'm working on max2011 and my nvidia driver version is 6.14.12.5981 with a quadro FX1700.
I'll update my driver right now to see if that solves the problem.
Pierre
Studiosezz PARIS
www.studiosezz.com
« Reply #3 on: January 28, 2011, 09:50:58 AM »
I just checked the display procedure of RailClone, but it's fairly simple and everything seems correct. I use the plugin regularly with Max 2010/2011, NVidia Quadro 4000 using the 3ds Max performance driver.
If other users have this problem, please report here.
robdeja
« Reply #4 on: January 31, 2011, 10:50:05 AM »
I've been getting this exact issue too. I also have a Quadro FX1700 running 259.81 drivers (60.84.63.0.17 bios version).
« Reply #5 on: January 31, 2011, 04:10:40 PM »
Is this same issue that you have reported in the other post ?
Do the objects dissappear completely from the scene or only from viewport ?
robdeja
« Reply #6 on: January 31, 2011, 04:34:15 PM »
I believe it to be a seperate issue.
If I hide/show the railclone object it reappears in the viewport which is a different behaviour to the other issue I reported.
« Reply #7 on: January 31, 2011, 05:24:05 PM »
Ok. We will investigate this issue.
