Author Topic: change default user librarie path  (Read 3311 times)
KiboOst
« on: July 05, 2011, 01:37:01 PM »
We have just bought railclonepro with network licences and I'm preparing deployment.
All is ready, installation and registry for default library path, but I can't find where (in registry, ini, xml etc) is the default location for user library path. I know I can edit it in max, but I don't want to have to, I want to deploy it, and next time a user start max, railcone is there with all configured (no user error then !).
railcone library is ever on the network (HKLM registry), so where can I change User's Libraries path without lauching max ?
Thks
yuv
  • iToo Software - CEO
    • Itoo Software
Re: change default user librarie path
« Reply #1 on: July 05, 2011, 02:06:16 PM »
The library path configuration is stored on registry keys, for system libraries (blue folders, read only):
[HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\Forest Pack Pro\LibraryDir]
"Forest Library"="C:\\Program Files (x86)\\Itoo Software\\Forest Pack Pro\\lib"
And for User's libraries,  (blue folders, user editable):
[HKEY_CURRENT_USER\Software\Itoo Software\Forest Pack Pro\LibraryDir]
"User's Libraries"="C:\\Users\\daniel\\Documents\\Forest Pack\\libs"
You can add any number of folders (local or network) in both keys, the only difference it is the read only setting for the system ones.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
KiboOst
« Reply #2 on: July 05, 2011, 02:42:57 PM »
Thanks Daniel, works great !
