Author Topic: Ignoring the direction of the line in spline section  (Read 1347 times)
DamianM
    • MONSUMM
« on: August 28, 2019, 04:21:25 PM »
Is it possible to do such a checkbox where we ignore the direction of the line and add a separate selection to the direction in which Railclone will be facing ?
The onlu method is continuous clicking and checking if the line has reversed properly.
I often generate lines from models and unfortunately they have different directions which can be painful especially when fixing it. Maybe it can be simplified somehow?
Re: Ignoring the direction of the line in spline section
« Reply #1 on: August 28, 2019, 04:28:17 PM »
RailClone calculates everything from spline start (splines do have 1st vertex for a reason)
RailClone can't know which direction it is facing.
I can only suggest some methods to find reversed splines quicker.
DamianM
    • MONSUMM
« Reply #2 on: August 28, 2019, 04:34:11 PM »
I would be very grateful if you could tell me the methods you mentioned.
« Reply #3 on: August 28, 2019, 05:14:07 PM »
Simplest way is to add extrude modifier and then shell with some material overrides.
Example:
Third shape is clearly different. Select it and reverse.
