Author Topic: gizmo helper as segment  (Read 2911 times)
GK6439
« on: August 25, 2011, 04:13:57 PM »
I was wondering if it was possible to use a helper (gizmo) as a segment in railclone?
atm it is not possible to select a helper as a segment?
(I created a lot of light posts with railclone and would like to replace them with a helper, maybe there is an other way?)
« Last Edit: August 25, 2011, 04:17:20 PM by GK6439 »
Re: gizmo helper as segment
« Reply #1 on: August 25, 2011, 04:55:25 PM »
No, it is not possible to use helpers as segments. RailClone is a procedural geometric object, so it only can generate a geometry as result, but helpers are a different type of object.
Perhaps you would use maxscript to identify the position of each light post in the geometry, and replace it with a helper, but unfortunately this is not a trivial task.
