Author Topic: ... is not a valid railclone object  (Read 4098 times)
Tryharder
« on: December 20, 2012, 12:50:22 PM »
getting this error message
error creating ... is not a valid railclone object
i create a library ... i create a railclone object ... go to properties select the max file and the thumb in the thumbnails folder ... but
the object gets inserted in the scene .,.. but as xRef object ... not inside railclone
can not  create a working user gallery
i am on  max 2013 design 64 bit ... win 7 64 bit ultimate
could that be problem of user rights ?
The Railclone Library works fine
« Last Edit: December 20, 2012, 01:05:17 PM by OM4143 »
Re: ... is not a valid railclone object
« Reply #1 on: December 20, 2012, 01:28:49 PM »
It is a problem of the Max object that you use to define the library item: it must be a full RailClone object, not a simple mesh.
Basically this should be the procedure to create a library item:
1) Create a full RailClone object, including all their segments, parameters and so.
2) Save it in a Max file.
3) Add the library item, selecting the object/scene created above.
Tryharder
« Reply #2 on: December 20, 2012, 02:22:46 PM »
... yes it´s true ... sometimes you stand in the middle of a wood and don´t see the trees
thanks a lot
Klaus
