Author Topic: segment edition  (Read 5131 times)
CarlosBZ
segment edition
« on: January 09, 2011, 01:38:51 AM »
I wonder if it is possible to edit segments of a surface created with RailClone pro. For example, I have a road on a slope, I want a segment of the surface created by the program can be conveniently rotated to generate a camber in the portion of the chosen segment. I know I can change segment profiles with construction rules but only at start, end or joints. I would like to select a portion and rotate it. I used skin and bones snapped to the spline, it works but maybe RailClone Pro has a way to do something similar.
Best regards.
CarlosB.
PD: wish list, intersections!
Re: segment edition
« Reply #1 on: January 09, 2011, 11:37:26 AM »
No, sorry, it's not possible. The rotation must be applied at the spline level, or editing the resulting mesh.
We like to add intersections to RailClone, but it may take some time. In order to support it, there are other features that must be implemented before (specifically in the User Inteface).
CarlosBZ
Re: segment edition
« Reply #2 on: January 09, 2011, 04:01:47 PM »
Should I rotate a node or a segment in the spline? would you elaborate, please?
Re: segment edition
« Reply #3 on: January 09, 2011, 05:01:19 PM »
Quote from: CarlosBZ
Sorry, my fault. I was thinking on rotating the spline's vertex to modify the RailClone's angle, but i just tried and unfortunately it doesn't work. The only way seems to be to modifyng the mesh.
CarlosBZ
Re: segment edition
« Reply #4 on: January 10, 2011, 02:12:52 AM »
Ok! thank you. Very good job.
Best regards.
