Author Topic: Struggling with a facade  (Read 3194 times)
Pierre
    • Studiosezz
« on: July 25, 2012, 03:34:00 PM »
hello,
is there a way to reproduce this facade ? I have to build many different building with this facade.
I can not build the corners (I try with windows in evently but I can't specify the good distance).
Thank you,
Pierre
Studiosezz PARIS
www.studiosezz.com
Jose
Re: Struggling with a facade
« Reply #1 on: July 26, 2012, 11:34:46 AM »
Hi, i created a solution that could fit for your scene, please see attached Max file and image:
In this model the walls for each plant is a RailClone object that has only segments: The Wall (Default rule), and window module that is repeated, (Evenly rule). Also i added another object RC with the floor spacing, it could have been included in the wall, but separately becomes easier to change the material.
I left the first spline different because on the ground floor the front left side has other window style. All other splines are intances each other, so that when you change any of them, updating the entire building.
Regards,  and I hope I've been helpful.
José Antonio Cordón
Itoo Software
www.itoosoft.com
jcordon@itoosoft.com
Pierre
    • Studiosezz
« Reply #2 on: July 26, 2012, 03:51:33 PM »
Well you help me a lot ! Thank you very much.
I'm always lost with the corner, i will study your example to understand.
Merci Merci Merci !
Pierre
Studiosezz PARIS
www.studiosezz.com
