Author Topic: Syncing Randomization of two different railclone objects  (Read 2868 times)
kmax
« on: December 07, 2012, 01:00:35 PM »
Is it possible to make two railclone styles randomize in the same way.
Example:
I have a lightpole railclone style which is throughout a road.But there is another railclone style which just adds another extension to the light pole.
Now this extension is not needed in all the lightpoles, otherwise i would have added it in the lightpole style itself.
There is a rotation randomization added to the lightpole and applying the same randomization to the extension, but it's not aligning with the light pole.
Is there any way that is possible?
Re: Syncing Randomization of two different railclone objects
« Reply #1 on: December 07, 2012, 01:32:15 PM »
If you want to use randomly two types of light poles (with or without extension), currently is not possible. Although this feature is already implemented on RailClone 2.x (under development).
If i understand well, are you using two RailClone objects on the same spline, one for the lightpole and other for the extension ?
In this case, would be possible to align both segments, if they share the same pivot point. Please, send us a test scene and we will check if everything is correct.
