Author Topic: Windows 8 problem  (Read 4317 times)
simmsimaging
Windows 8 problem
« on: December 08, 2012, 12:16:57 AM »
I have installed Windows 8 on one render node. Using it for DR renders with vray from my workstation is no problem but using it for DR renders via back burner isn't working. I am getting dozens of buckets across the render (far more than I have cores for) that just stall out.
I have seen this before with mismatched plugins but that isn't the problem here. Any known issues with back burner, railclone and windows 8? It's probably something I am doing but I don't want to waste more time on it if is something else. :)
Again, it works fine with regular Dr renders just not when the host is a back burner render.
Tks in advance.
B
Re: Windows 8 problem
« Reply #1 on: December 08, 2012, 01:02:47 PM »
We had no time to test Windows 8 yet, anyway a plugin cannot modify the number of buckets. That depends exclusively of Vray.
We will test it as soon as possible.
simmsimaging
« Reply #2 on: December 09, 2012, 03:44:43 AM »
It is a problem I have seen before with a plug in problem but not sure that it's vray specific. It is a weird artifact thing. I will send a screen capture next time I get it to happen.
As an update: I got another scene to render ok in both regular and DR renders via back burner. I need. More time to test it with some other scenes, but but this one scene was rendering ok prior to the windows 8 upgrade to. I will keep you posted.
simmsimaging
« Reply #3 on: December 12, 2012, 07:53:39 AM »
just an update: it's fine now. I re-installed the plugins on all my nodes and it has fixed it. I must have had a mis-matched version of something in there. Anyway, it seems okay now.
Thanks!
b
« Reply #4 on: December 12, 2012, 06:56:30 PM »
Ok, thanks for letting me know.
