Author Topic: ER: Compose Counter  (Read 306 times)
ER: Compose Counter
« on: October 28, 2021, 09:21:11 AM »
How about adding a Counter option for Compose operator (like the Sequence operator) when Sequence Mode is selected?
I just run into an issue about adding some Segments in a Compose operator driven by a Random parameter and I had to nest L1S to accomplish that.
« Last Edit: October 28, 2021, 09:33:29 AM by Dragan »
Re: ER: Compose Counter
« Reply #1 on: October 29, 2021, 09:36:39 AM »
The Compose operator is very different from the Sequence operator (i know the 'Sequence' mode may lead to confusion).
It was designed to insert ALL Segments one after the other, and its sequence cannot be modified.
When used as a Default segment, Compose and Sequence generates a similar result.
But you can see the difference, for example, used as Corner segment: Compose inserts all segments, but Sequence only one.
« Reply #2 on: October 29, 2021, 09:53:13 AM »
Hi Carlos,
Yes, I know all the differences between those two.
I was targeting Counter only for Compose/Sequence Mode to avoid multiple wiring if I need multiple segments, but I guess nesting L1S as a workaround is not a big deal to do.
Thank You.
