Author Topic: L1S - For No Slice  (Read 2125 times)
L1S - For No Slice
« on: March 14, 2023, 10:35:11 AM »
Please check if this working fine.
Re: L1S - For No Slice
« Reply #1 on: March 14, 2023, 11:48:50 AM »
Hello Dragan,
Would you mind elaborating a bit on this issue. I've just tried various no-slice options but all seem fine.
Cheers,
« Reply #2 on: March 14, 2023, 12:01:34 PM »
Hm. For me is always returning whole segments. Let me restart. maybe it is a glitch.
« Reply #3 on: March 14, 2023, 12:04:06 PM »
If you reproduce it, please feel free to send us the file. Thanks!!
« Reply #4 on: March 14, 2023, 12:13:52 PM »
If Segment is set to "no slice" or overridden with Transform/Deform it will not have an effect on General> No Slice> Remove or Slice. It always preserves the final segment.
« Reply #5 on: March 14, 2023, 01:40:24 PM »
Hmmm - that's the expected behaviour. The "For No Slice" setting only affects segments that are affected by a clipping spline (it in the clipping are group of the UI). It has no effect on the final segment on the X Spline.
Cheers,
« Reply #6 on: March 14, 2023, 01:47:26 PM »
Ah... Yes.. Clipping
Sorry, I'm a little bit tired from a few parallel projects.
But, nevertheless, how about this as a new feature? So if the segment is out of the Spline/Distance range to be affected as it will be with Clipping Spline.
I just try to do some nesting and this type of behavior would be just right for me so I do not have to add Null at the end or Limit the End side to cut out the extended segment.
