Author Topic: Center Alignment  (Read 780 times)
Center Alignment
« on: September 16, 2019, 02:39:50 PM »
I`m testing X/Y evenly division but also try to compensate start/end "problem" using Segments 1/2 Size for limit paddings.
First Generator uses Center X/Y Alignment for all segments and it is quite a messy results.
The second Generator uses a combined X/Y Alignment for the segments but still get gaps at the bottom area.
Maybe I missed something?
beta 405
    • iToo
Re: Center Alignment
« Reply #1 on: September 18, 2019, 03:28:00 PM »
Possible solution :
Leave it at automatic for the bottom row and chang the Bottom Padding instead.
File attached (thanks, Paul).
« Reply #2 on: September 18, 2019, 04:39:57 PM »
Hi Rokas.
I was targeting for equal space on evenly so ID1 will not do the job. (Although I already have Macro for this).
For ID2: Yes, in RC almost always I can find some workaround. I was actually referring to possible issue in the calculation for that bottom section.
Thank you.
BR
