Author Topic: Light supporting Deform Stepped Mode  (Read 1906 times)
« on: November 21, 2021, 08:43:20 AM »
Neither in single nor part of the group, the light segment does not support stepped mode for light. The light segment will always follow a spline orientation.
Can something be done for light supporting Stepped mode?
tnx.
« Last Edit: November 21, 2021, 10:45:04 AM by Dragan »
Re: Light supporting Deform Stepped Mode
« Reply #1 on: November 21, 2021, 10:56:26 AM »
Looking for some workaround results.
I tried to override  Banking/X rotation and that return some results and I managed to reset X rotations to zero.
Then I thought to reverse Z rotation using XSplineXdirection.z, and this was close but I don't think I use the right Attribute.
I think there is no use of light if they can follow Geometry Segments and most of the time for the lights on the staircases we need to use Stepped mode.
Any idea how this can be done.
« Last Edit: November 21, 2021, 11:06:44 PM by Dragan »
« Reply #2 on: November 22, 2021, 12:08:25 PM »
Thanks for letting us know about this limitation Dragan. Dev team is looking into it.
All the best,
« Reply #3 on: November 22, 2021, 12:57:44 PM »
Fixed for next update. It was affecting to "Force Instance" as well.
« Reply #4 on: November 24, 2021, 11:24:03 AM »
Stepped mode is fixed. Thank you!
Apparently, now I have issues with lights. Either the lights not working or I got errors on instancing in Vray.
Did you try to Render my test scene? (I think there are checked force instancing somewhere in Segments Deform or Transform override)
« Reply #5 on: November 24, 2021, 02:02:28 PM »
Something is wrong with Vray Lights, they are not rendering anymore, Corona renders fine.
RC 5.0.4
« Reply #6 on: November 24, 2021, 02:07:08 PM »
I just checked I`m on Vray 5.1 here and it has to be vray 5.2? Right?
« Reply #7 on: November 24, 2021, 02:25:11 PM »
That'll be it. V-Ray 5.2 is needed for light instancing.
« Last Edit: November 24, 2021, 02:34:04 PM by Paul Roberts »
« Reply #8 on: November 24, 2021, 02:29:17 PM »
Yeah, it is not my day today :D
My wife is jumping on my nerves... Black Friday... Roomba, samba, cha-cha robot vacuum cleaner.....  :o :o :o >:( >:( >:(
« Reply #9 on: November 24, 2021, 02:53:07 PM »
Tested on 5.2. Works fine.
Stepped lights are a huge help. Great job!  ;)
« Reply #10 on: November 24, 2021, 02:54:17 PM »
Great! Glad it's all working well.
