Author Topic: Macro Copy Paste >> Wrong Parameters order  (Read 1883 times)
« on: October 03, 2019, 08:39:01 AM »
Specific Macro has some parameters exported by default and some parameters exported manually from macro.
First Copy>Paste produces some wrong Parameter order.
After Copy>Paste the Macro created by previous copy/paste operation all Parameters have the right order.
Re: Macro Copy Paste >> Wrong Parameters order
« Reply #1 on: October 03, 2019, 08:49:00 AM »
Hi, while this is not fixed You can go to macro, then go to "Define Parameters Order"
Make any change there. Click OK. Now Your copy paste macro should behave correctly.
« Reply #2 on: October 03, 2019, 09:13:43 AM »
Hi Rokas..
I just made a simple test with 10 numeric parameters and notice issue.
All parameters are ascending sort by "Define parameter order" form Numeric1 to Numerc10.
Numeric 1-5 are exported by default and numeric 6-10 can be exported manually.
Issue to reproduce:
Export manually parameters one by one:
1. Export manually Numeric10
2. Export manually Numeric6
3. Export manually Numeric8
After copy>paste a Macro, manually exported parameters are keeping the order set by "Define parameter order" and not the order get by "one by one" manually export but connectors seams to connecting  "side by side" parameters and that return wrong result.
« Reply #3 on: October 03, 2019, 09:26:55 AM »
illustrate
« Reply #4 on: October 03, 2019, 09:31:30 AM »
Dragan, thanks for the steps. We know of the issue.
I just tell You procedure how to fix it in Your current style, before we do permanent fix in future update:
« Reply #5 on: October 03, 2019, 09:33:41 AM »
Solution works in Your attached file too.
« Reply #6 on: October 03, 2019, 09:39:36 AM »
Thank you Rokas for your effort.
We are still in Beta test.
If you confirm the bug, please don't waste your time on me finding the workaround. ;)
Great support!  :D
Best Regards
