Author Topic: Macro Errors in RC 3.1.6 beta  (Read 1072 times)
Shawn Olson
  • Wall Worm
    • Wall Worm
« on: May 12, 2018, 08:47:36 PM »
After installing 3.1.6 beta I am getting this error when I right-click a node and chose Move...:
Code: [Select]
-- Error occurred in anonymous codeblock; filename: C:\Users\smols\AppData\Local\Autodesk\3dsMax\2019 - 64bit\ENU\usermacros\Forest Pack-FP_MS_SelectAll.mcr; position: 141; line: 5
-- MAXScript MacroScript Error Exception:
-- Type error: Call needs function or class, got: undefined
-- MAXScript callstack:
-- thread data: threadID:16320
-- [stack level: 0]
-- In isVisible(); filename: C:\Users\smols\AppData\Local\Autodesk\3dsMax\2019 - 64bit\ENU\usermacros\Forest Pack-FP_MS_SelectAll.mcr; position: 142; line: 5
-- member of: codeblock macroScript: Forest Pack_FP_MS_SelectAll
-- Locals:
-- isForestPack: undefined
-- Externals:
-- owner: <CodeBlock:Forest Pack_FP_MS_SelectAll>
-- Forest Pack_FP_MS_SelectAll: <CodeBlock:Forest Pack_FP_MS_SelectAll>
-- [stack level: 1]
-- called from codeblock macroScript: Forest Pack_FP_MS_SelectAll
-- Locals:
-- Externals:
-- [stack level: 2]
-- called from top-level
Shawn Olson
  • Wall Worm
    • Wall Worm
Re: Macro Errors in RC 3.1.6 beta
« Reply #1 on: May 12, 2018, 08:48:59 PM »
I seems errors are related to these lines in macros:
on IsVisible return (isForestPack $)
AND
on IsVisible return (isRailClone $)
Shawn Olson
  • Wall Worm
    • Wall Worm
« Reply #2 on: May 12, 2018, 09:10:07 PM »
Actually, it turns out, this is a wider issue. Both RC and Forest are simply missing from Max after installing these latest betas.
FC1888
« Reply #3 on: May 12, 2018, 09:17:25 PM »
Sorry to go a little off topic, but on checking the first post, I saw "Max 2019" and it just made me cringe. Makes me wonder..  if this issue is applicable to other versions of Max or is it just a 2019 thing.
Shawn Olson
  • Wall Worm
    • Wall Worm
« Reply #4 on: May 12, 2018, 09:19:44 PM »
I now know the issue.
Forest installed into the current Max BETA version instead of into Max 2019.
« Reply #5 on: May 13, 2018, 09:06:16 AM »
Hi, these errors are caused by a missing masxscript used for the "Quad" menu, both in Forest and RailClone.
Specifically the maxscript files are: <max folder>\scripts\Startup\forestpack.ms and railclone_utils.ms.
It would happen in two cases:
1) If the plugin is installed, but for some reason the script is missing or was not exectuted at Max startup.
2) When the plugin is uninstalled, Max keeps a copy of the macroscript used in the Quad menu, even if the plugin was removed correctly.
In this case, you can fix it deleting the macroscript copies, as described here.
Shawn Olson
  • Wall Worm
    • Wall Worm
« Reply #6 on: May 18, 2018, 04:05:22 PM »
Thanks Carlos. I solved by editing my registry to fix the 3ds Max 2019 path which had been changed by a beta install to the incorrect path. Once the path was fixed, reinstalling Forest/RC fixed the problem.
