Last time I managed to get my SINGLE MARKER for Extended A2S and as you can see it turn out very useful.
![Cool 8)](https://forum.itoosoft.com/Smileys/default/cool.gif)
Now, it is difficult to explain how I would like the marker to behave but my initial thought was to add MatID in Referencing for markers.
Example:
- Again, only a SINGLE marker on the Spline without any Segment connected to the Marker Input.
- Base Spline divided into subsplines with different IDs
I would like to have the same workflow as with a single marker for Extended A2S, if there is no Segment connected to the Marker Input, that SINGLE marker should act as an active or as a normal Parameter.
And, basically, it works until Limit ID is in play, and after that everything breaks.
Since the generator resets on each Subspline ID I would like either:
- marker referenced to Vertex to have an influence on a particular Segment at that point
- or just ignore Limit ID
Hope that makes any sense.
thx
