Author Topic: Master behaviour  (Read 541 times)
Master behaviour
« on: July 03, 2019, 01:11:30 PM »
Hi.
First of all, thank you for all effort on releasing RC4.
We had topic https://forum.itoosoft.com/railclone-pro/railclone-facade_nesting-windows-problem/msg21658/#msg21658
about:
A nested segment cannot be `recalculated` to retain Master behaviour and can only be scaled to fit `nested space`
As I can see on first look, Nested Generator should be able to solve this issue but on the first hours of testing, I could not achieve any positive results. Should I try any more or this issue remains on RC4?
Best Regards.
    • iToo
Re: Master behaviour
« Reply #1 on: July 03, 2019, 01:16:01 PM »
Can You please illustrate this with starting scene and what You want to do.
« Reply #2 on: July 03, 2019, 01:29:08 PM »
Simple window frame =  Master generator (Xsize&Ysize =100 cm/ simple box segment 10x10x10cm to Start/End/Top/Bottom/Corners)
Second Generator: Extended to Clipping Spline
My Goal to nest Master gen. (window frame) to fit Clipping Spline (usually contain multiple splines) but to retain original 10cm frame  size.
I`ll provide a scene.
« Last Edit: July 03, 2019, 01:33:59 PM by Dragan »
    • iToo
« Reply #3 on: July 03, 2019, 02:20:33 PM »
I was not sure what is "Master" what is "Frame" in Your file but I have mocked a simple nesting example.
P.S.
You can't have all the flexibility with Clipping splines. I recommend to avoid them when You can. Sometimes You can't then use it. But then You do lose some flexibility- one of thing You lose is XSplineLength parameter.
« Reply #4 on: July 04, 2019, 07:29:05 AM »
Yes, I understand. I was kind of hoping it will be possible to get X/YSplineLength from closed rectangular splines  8) :D.
However!!! With combination XSplineLength + Spline Markers Data now I can easily drive both X & Y size.
Works like a charm. Great job guys!!! Thank you!
Best Regards
P.S.
I have some additional question in Note of attached file.
pls. if any file, downgrade it to MAX2015
Thank you
« Last Edit: July 04, 2019, 08:33:02 AM by Dragan »
« Reply #5 on: July 04, 2019, 11:07:44 AM »
Please ignore 1 question (solved by taking full Y Size and subtracting Top/Bottom Ysize)
Nesting generators is a whole new perception of using RC!  We can now beat HoudiniFX users.  8)
