Author Topic: Scale Segment  (Read 463 times)
Scale Segment
« on: August 06, 2019, 02:39:02 PM »
Is this normal behaviour?
First Transform should Scale segment on the Z size and if I connect it to e.g. Evenly it`s ok.
The second Transform should make virtual sizebox along X for Default placement but not affect the scale of the segment.
I think that was possible in RC3.
Re: Scale Segment
« Reply #1 on: August 07, 2019, 10:41:12 AM »
Yes, that's the normal behaviour. It's not possible to apply different "Fixed Size" modes to a same segment. RC uses the lastest one.
I just tested in on RC3 with same result.
Re: Scale Segment
« Reply #2 on: August 07, 2019, 10:54:03 AM »
Thank You Carlos
I just try, Transform Scale will do the job.
Maybe to apply this as Enhancement Request?
Re: Scale Segment
« Reply #3 on: August 07, 2019, 11:32:05 AM »
I will take a look to it, but seems problematic.
"Fixed Size" is computed in a different way depending if Scale is on or off. I'm not sure if we can mix both modes.
