RailClone => RailClone Pro (*) => RailClone Pro Beta => Topic started by: Dragan on September 22, 2019, 10:52:03 AM
Title: slow RC command panel respond when creating RC object
Post by: Dragan on September 22, 2019, 10:52:03 AM
Hi.
Sometimes I get very slow RC command panel respond when creating RC object.
It can go up to 7 seconds to create RC icon in the viewport.
Also, the RC icon is not selectable by simple LMB. Instead, I have to select RC object in Scene Explorer or Select RC icon by rectangular selection.
Title: Re: slow RC command panel respond when creating RC object
Post by: iToo on September 23, 2019, 09:46:03 AM
Hi Dragan,
I see from your other post that you're using Max 2015.
I remember there was a similar bug, which was fixed for Max 2016 and above in the latest service packs (i cannot find any reference for 2015):
https://knowledge.autodesk.com/sites/default/files/file_downloads/3dsMax2017_SP2_Readme.htm
MAXX-30316    Slow node creation / modifier application in complex scene
But checking in the Autodesk forums, i found this interesting thread:
https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-2015-slow-interface-reaction-and-lags/td-p/5241101
It describes several workarounds, which worked in some cases. As deleting the 'AppData' Max folder.
But first of all, i would suggest you check if Max is updated to the latest Service Pack (SP4).
Have you experienced this issue with any other plugin or comand, besides RC4 ?
Post by: Dragan on September 23, 2019, 09:59:22 AM
Hi Carlos,
yes deleting the 'AppData' Max folder usually helps.
