Author Topic: Temporary stop "under the hood" calculation  (Read 1482 times)
« on: October 03, 2019, 01:28:24 PM »
Hi.
I was too ambitious and made the Macro with a really complex network style and 40+ parameters to use.
When this Macro is multiplied in the Style editor everything becomes really slow.  :(
Even placing a Numeric node will take a few seconds.
This is expected and I know there is not much that can be done to make things faster.
But, when I temporary switch off the Macros everything is working at normal speed even though without realtime results.
I was thinking about some options such as RMB click on empty Style Editors workspace and command like Temporary stop "under the hood" calculation.
I know it can be "little" dangerous if we mix up some connection/parameters and "activate" calculation after "pause" but if we know what we are doing at least we could speed up some process.
I hope this makes any sense?  :o 8) ;D
Best Regards
Re: Temporary stop "under the hood" calculation
« Reply #1 on: October 03, 2019, 01:34:14 PM »
We have found some performance leaks. Probably they are related to what You have in Your situation as well. Maybe not. We are investigating.
To stop under the hood calculations I very often disable autobuild mode:
« Last Edit: October 03, 2019, 01:36:31 PM by Rokas »
« Reply #2 on: October 03, 2019, 01:55:43 PM »
Ah, yes... this could be it!!!
I just finished my Macro for creating a Window Frame. It works as expected without bugs but could be slow in calculations. I'll do a video to demonstrate how it works and if you need it I could send it at support mali if it could help you testing RC performance.
I just need to rearrange it and do some notice.
