Author Topic: Creating Roofs with RailClone  (Read 315451 times)
« on: November 14, 2017, 10:48:54 am »
Please post any question or comments about the Creating Roofs with RailClone tutorial here.
« Last Edit: November 15, 2017, 11:02:32 am by Paul Roberts »
amitgedia
Re: Creating Roofs with RailClone
« Reply #1 on: November 15, 2017, 06:22:03 am »
it was there 2 days back on the tuts page, why its gone now, are you guys updating the files or the video, because i downloaded the tut files and it gave me an error about vray, mass effect etc and also i think there is physical camera in the scene which might not be compatible with older versions of 3dsmax...
« Reply #2 on: November 15, 2017, 09:04:48 am »
Hi, thanks for reporting that. We'll look into it. It does require a quite recent version of V-Ray and you may get a MassFX error because it was created in 3DS Max 2018 and saved back to 2015. You can safely ignore it though. I'll look into swapping the physical cameras.
amitgedia
« Reply #3 on: November 15, 2017, 12:06:05 pm »
Hi Paul,
Thanks a lot for the quick reply.
I am using the vray version 3.60.03 and also 3dsmax 2015 so i think using ofnormal vray physical camera might be useful for many user who are still using older versions of 3dsmax...
Thanks a lot again....
« Reply #4 on: November 15, 2017, 12:17:03 pm »
Thanks for the extra information. I've swapped all the Physical Cameras for V-Ray cameras and removed the MassFX warnings in the new files so hopefully that will help out. Files are now saved back as far as 2014 as well. They should be available now.
Thanks again,
CQ4419
    • GC STudio, Paris
« Reply #5 on: November 23, 2017, 09:47:04 am »
Hi Paul
As we talk about it when I asked you a month ago, if you were going to create a tutorial on the roofing... you did it !
And what a tutorial !
You tell at the end that there are thousands of applications, and that's the case!
What a step forward once again!
Thank you so much and congrats again
Roland
rahmanpadne
« Reply #6 on: March 18, 2018, 11:11:49 am »
Hi guys....im new to railclone and trying to create a roof top with railclone. since the spine profile is little improper, im achieve the result. ..please looking for any help here..REALLY APPRECIATE IT!!!
iancamarillo
« Reply #7 on: March 24, 2019, 08:43:45 am »
Hi, I’m new to railclone and did this tutorial, which was very helpful, thanks! I have a project that’s in concept phase so I’d like to set something up that’s generally flexible because the building is changing often. The roof is organic and has many openings and I’m wondering if I should use conform or even forest pro? Attached is a reference image similar to the shape. Thanks!
Sknueppel
« Reply #8 on: March 29, 2021, 12:18:20 pm »
Hey there,
My question is not about a roof but about the technique for slicing planes.
I merged all splines to one and gave them an individual Mat ID. checked the hierarchy Checking by Mat ID and hoped that it would slice correctly.
I m pretty sure something is missing?!
Thank you in Advance
« Reply #9 on: March 29, 2021, 12:34:11 pm »
Hi there.
Thanks for the file. I think I can see why it's not quite working as expected. The Clipping tools in X>XY mode  tend to work best when both the Spline object and the RailClone object are aligned to the world axis. To fix your scene:
  • Reset the XForms for the Spline to realign the pivot to the world
  • Set the rotation for the RailClone object to 0 on all axes
I hope that helps,
Sknueppel
« Reply #10 on: March 29, 2021, 01:02:32 pm »
Thank you so much...
Great support ;)
kcpr raffaEl
« Reply #11 on: November 26, 2022, 12:34:32 pm »
Hello!
This Tutorial is great!
One thing I would suggest - while opening Tutorial Files with Railclone Lite there is no possibility to view/edit/modify Railclone objects due to Lite version limitations (no more than 2 segments).
Can we please have 2 segments option for Lite versions? For example mirrored segment on egdes of roofing?
Thank You!!
