Author Topic: RailClone Stadium  (Read 312864 times)
Ihno
  • Guest
Re: RailClone Stadium
« Reply #15 on: June 03, 2016, 02:12:23 pm »
I'm using 3ds max 2016 SP3 and RailClone 2.6.0 I'm also using the brand new Vray 3.40.01
Which I thought may cause the problem, but turning of the instance engine dosn't help.
« Reply #16 on: June 03, 2016, 02:18:56 pm »
Are you able to upgrade to the recent beta?
http://forum.itoosoft.com/index.php?topic=3756.0
There are a few bug fixes that may affect styles that have vertices with angles of exacty 180 degrees. If that doesn't help if you could upload a max file with just the problematic objects here, I'll check it and perhaps it will reveal something.
Many thanks,
Ihno
  • Guest
« Reply #17 on: June 03, 2016, 02:44:09 pm »
Jep, that fixed the issue, thanks  ;)
« Reply #18 on: June 03, 2016, 02:53:32 pm »
Great! Glad we could help out.
Eugene
« Reply #19 on: August 08, 2019, 12:08:02 pm »
Hi, I have a problem with rendering the audience. I have attached random materials to people (like in the tutorial) and can see them well randomized in the view port. But when rendering all people have the same material ID. I use 3ds max 2017 and Corona 3. Perhaps you can explain why this happens?
Eugene
« Reply #20 on: August 08, 2019, 01:15:20 pm »
Hi Eugene,
Please try  with disabled instancing
