Author Topic: Creating Cityscapes with RailClone  (Read 574483 times)
« on: February 25, 2019, 10:13:14 am »
Post your questions and comments about the Creating Cityscapes with RailClone tutorial here.
vfxmonster
Re: Creating Cityscapes with RailClone
« Reply #1 on: February 26, 2019, 05:56:39 pm »
Hi Paul,
I noticed the tutorial video mentioned that the secondary RailClone arrays would be included in the tutorial files for the sidewalks, streetlights, people walking, etc.  However when I opened the tutorial files, included were the city grid spline and a maxscript file for the randomization of material ID's.  I'm not sure if it's an issue with my version of Max (2017) or a download error.
I very much would love to learn how to properly implement the other assets into the city.  Ironically this tutorial was released 2 months after we had to build a city out for a Nissan CES keynote presentation.  Being a new user to RailClone and ForestPack (bought it for the Nissan project) I'm just beginning to comprehend how powerful these two packages are together.  After watching the tutorial I see how we could have done it much better with this methodology and was hoping to learn more proper methods of using RailClone from your implementation of all the assets to populate the streets.
Best,
Sean
vfxmonster.com
MG2644
« Reply #2 on: February 27, 2019, 08:34:17 am »
As vfxmonster pointed out, the tutorial file provided only contains city grid spline. It would be really great if you can provide us the tutorial file with all the assets used in the video. I've been working on several city models for architectural visualization purpose and really curious to see how you populated sidewalk, road etc.
TomDArch
« Reply #3 on: March 01, 2019, 04:25:02 am »
You mentioned at the start of the video a previous tutorial on benerating a parametric building with Railclone.  Could you provide a link to that tutorial please?
Pelo1989
« Reply #4 on: April 01, 2019, 09:18:29 am »
Hi Paul,
I can't find the tutorial's file with all the railclone's objects, it could be possible to receive it? because i love this tutorial, but without the main file I can't understand how to make the detailed part of the city like pavement for examples.
Thanks a lot for your availability, best regards,
Federico.
thhm
« Reply #5 on: August 29, 2019, 02:57:13 pm »
can you share the vray material for the roads that use the distancetex pls?
Thanks!
« Reply #6 on: August 29, 2019, 03:23:23 pm »
Thanks!
Hi, unfortunately assets used in this tutorial are copyrighted and can't be shared.
Thanks for understatement.
Totek
« Reply #7 on: January 23, 2020, 06:45:37 pm »
Hi i'm posting here because I'm a bit confused,
I recently bought railclone and followed the first part of this this tutorial, everything went well except for some of buildings geometry getting fliped on the side (see attachment), it does the same thing at the start of the tutorial but it is not explain how to fix this.
This might be very simple to fix this but i can't figure it out, can somedy explain me how to do this plz? :)
« Reply #8 on: January 23, 2020, 07:01:42 pm »
Hi, check the Pivot orientation on the original Building model.
Totek
« Reply #9 on: January 23, 2020, 07:17:05 pm »
hey thanks for the reply!
I allready did that but it didn't solve my problem
« Reply #10 on: January 23, 2020, 07:43:07 pm »
Can you share the Scene, please?
Totek
« Reply #11 on: January 23, 2020, 08:57:18 pm »
Sure, here is a link to download it, i just simplified it a bit.
https://we.tl/t-rDHsPmluht
Thank you for the help again!
« Reply #12 on: January 23, 2020, 09:35:14 pm »
I can't open it. I`m on MAX2018.
You can use `Select Dependent objects` script from this link:
https://forum.itoosoft.com/railclone-pro/scripts-for-railclone/45/
1. Select RC object and start the script. It should select RC+all object+splines
2. FIle>Save Selected (use Save as type 3ds Max 2017)
That should work and isolate just problematic RC object
Totek
« Reply #13 on: January 23, 2020, 10:04:08 pm »
Here is the 2017 version.  :D
https://we.tl/t-tAvKRR3nxO
« Reply #14 on: January 23, 2020, 10:59:45 pm »
 ;D
Nope, sorry, still reporting version number 20000
try to isolate just RC
