Author Topic: Parameterising Windows with RailClone  (Read 874675 times)
hehJgunen
Re: Parameterising Windows with RailClone
« Reply #60 on: March 22, 2019, 07:02:54 pm »
HI, is it any chance to make open windows?
« Reply #61 on: March 22, 2019, 07:14:22 pm »
With RailClone 3, it'd be a lot of work. In a future version of RailClone we are adding a few new features that should make that sort of thing easier.
Thanks!
hehJgunen
« Reply #62 on: March 23, 2019, 03:41:09 pm »
Great to hear it, can't wair for next release then :)
HS9343
  • Guest
« Reply #63 on: November 21, 2019, 10:11:29 pm »
If I check "extend x/y to area" the projection option is greyed out. As understand it, I need to have four separate RailClone objects in order to have parametric windows on all sides of a building. Is there a smarter way to setup the windows to go all the way around the a building? thanks!
« Reply #64 on: November 22, 2019, 10:45:03 am »
Hi!
Actually in recent versions of RailClone it is not necessary to create a different RC object for each side of the building. RailClone can rotate each window to match the spline. If a window faces in rather that out. reverse the spline to fix it.
The settings to enable this mode are as follows:
Hope that helps,
HS9343
  • Guest
« Reply #65 on: November 22, 2019, 04:09:56 pm »
thanks....brilliant!
« Last Edit: November 22, 2019, 04:15:06 pm by SeanyMac »
Young chul yoon
« Reply #66 on: December 27, 2019, 03:06:32 pm »
before I write a more thorough answer to address your questions I wonder if you can upload your file so far so I can take a closer look at what's going on. If you'd prefer not to post it publicly please feel free to send it to support@itoosoft.com.
I'll write a more detailed response soon and double check the script too.
Thanks!
Target
« Reply #67 on: June 29, 2020, 04:29:26 am »
RB2300
    • DEVconstruction
« Reply #68 on: October 25, 2020, 07:15:29 am »
Hello please, I am trying follow tutorial and I have problem that first pieces is not same as in tutorial ... they are in angle... please can someone help me and tell me where is issue? Best regards Pablo
RB2300
    • DEVconstruction
« Reply #69 on: October 26, 2020, 04:22:40 am »
I have tried continue and see what happends after while... i see there is another problem at 9:22 min ... I put there your expression
if(YSplinePosition = 0,3,
if(YSplinePosition = 1,1,2))
and it shows me
Parse error. Expected ')' or ',' in argument list at line 1:
it seems that you used old version and through period you updated your software and it doesnt work any more this tutorial because you changed it so much... But is ok i will try use your example file and use that script that works at least.
« Reply #70 on: October 26, 2020, 08:03:05 am »
Since the tutorial we updated RailClone a lot.
Expression editor functions has been expanded. And that required some changes how they are written.
Test expression "-1*(Input/4)" in v2 should be written in v3 and v4 like this:
return -1*(Input/4);
Basically all expressions should have "return" in start of "expression" and You should end them with ";"
Also in latest RC You need to use double equal "==" to make comparison.
example:
return if(XSplineMatID==12 | XSplineMatID==112 | XSplineMatID==45 ,1,2);
More examples can be found here.
MJ1568
« Reply #71 on: November 04, 2020, 07:58:43 pm »
I followed exactly the steps in the tutorial. Everything is functional in the parameterising window only de x evenly is not doing what it has to supposed to do.
any idea what is going wrong?
And where can i find the script "Railclone Slicer"?
attached the working file.
thanks already!
MJ1568
« Reply #72 on: November 04, 2020, 08:21:15 pm »
Just solved the problem! only with the script "Railclone Slicer" you can help me.
thanks!
MJ1568
« Reply #73 on: November 12, 2020, 10:42:32 am »
Hello
I followed the “Parametric window tutorial” But ended up with the following problem: the x and y evenly are lower then the rest of the window object?? Attached a jpg and max file.
Hope somebody can help!
« Reply #74 on: November 12, 2020, 01:40:27 pm »
it is all about Your segment pivots.
Set align their Y to the same plane.
